pavanabatchu
What is unclosed profile?
Can unclosed profile be extruded?
What does ANCHORING the profile do in sketcher w/b?
In how many ways you can select XY Plane?
The actual process of extruding a profile adds what branch F3?
List two different methods to delete an entity?
What three things must be selected to create a hole that is accurately located in a part?
How would U modify:
The diameter of a hole that is already created?
The location of a hole that is already created?
V5 gives U several methods to rotate a part. (Changing the parts relationship to 0,0,0 point).
How can specification be expanded to show additional branches?
What is default color of the part while be updated?
What 2 things must be selected in order to use the rotate command from the Transformation features?
What are the mode options available while creating chamfer?
What are the steps to create a New body?
What are the similarities b/w Part design & Drafting workbenches?
What determines the size of fillet when TTF is used?
Describe the process to subtract one body from another?
What must be selected before components are inserted into the Assembly w/b?
What tool is used to move the parts in Assembly w/b?
How do you split the screen so that u can see the cat Drawing & Part design screen at a time?
List 2 different methods of moving the parts in Assembly?
Manipulate & Compass
What are the 5 options available to create a line?
What tool must be selected to see the hidden objects?
What are the 6 options for creating a plane?
What tool is used to a solid (Part body) from a surface (Open body)?
In GSD which tool is used to define the part thickness?
What is profile in relationship to Sweep tool?
What is Guide curve in relationship to Sweep tool?
A plane is required to complete the sweep operation?
How could the DMU navigator be used in Product Review Process?
What tool inserts a part or assembly file into the DMU navigator w/b?
How do you move the horizontal ground grid if it is activate?
Difference b/w Fly Mode & Walk Mode?
Basic equations about Surf2, Patch and Blend surf?
What is tangent continuity/ curve continuity? What are the methods to check them?
Is it possible to sew a SURFACE to a SOLID? --------YES
In a dummy solid there is a hole of 50mm. Is it possible to fill that hole?
Soln: Yes, Using Thickness or Remove face
In a sketch if 2 closed profiles are intersecting with each other. Is it possible to extrude either of the curves? --------YES
In assembly w/b are there any options other than constraints to position the parts, or products?------------------ 1.Snap 2.Smart move 3.Manipulate 4.Compass
What is the operating system on which CATIA works?---------UNIX & WINDOWS
Can you change a BODY to a Part body?
Is it possible to re-order the tree in assembly?----------Graph Tree Re-Ordering
How many parts can we select at once in Graph Tree Re-ordering?---------ONE
How to change the units?
How to change/perform:
Change sheet size & Angle of projection?
Align dimensions, Re-route?
Represent hidden line, Centerline, Axis line?
Add/Remove leader, Break point, Interruption?
Fake dimensions, hide/show frame
Section line direction, Arrow type?
Pickable in drafting?
Half dimension, Stacked dimension, Cumulative dimension, folding lines?
Deactivating annotation, tables & rows
Front view using
Local axis system.
Selection sets
View generation mode?
Indicate Horz/Vertical dimm for circular object?
Copy & Paste?
Inserting BOM, Background view, CGM?
Insert sketch dimensions?
Insert Dia. symbol, Sub & and super script, Hole dimension?
Define the following:
Driving dimension?
Selection callout?
Advanced front view?
Types of:
Views
Selection view
Constrains
Any possibility of increasing
Can individual sketch be saved?
How do you change the drawing units?
List all the geometric symbols?
What is sewing?
How to remove clipping in the view?
What is healing geometry & freeze elements in Healing?
What is the use of Remove Lump?
What is Reframe on and Center Graph?
What is the use of PULLING DIRECTION in Rib Option?
How to create a plane at an angle to another plane?
What is the different type of coupling modes in loft?
What is simplified representation in pattern?
How I can place the place instances on both sides of original feature?
How do pattern the two features at a time?
What is meaning of explode in pattern?
Explode option does what in mirror feature?
What is the meaning of rows in direction in pattern?
What does thick option do in pad command?
Is it possible to create a pad along any direction?
Difference between pad and multipad?
What is design table?
What is association and disassociation design table?
What is the use of Duplicate data in catia model in DT?
What is Resolve in CATLOG?
What is Thickness? Can we use contoured face for thickness?
What is split surface? can we use contoured surface for splitting
What is Sew surface?
Difference between sew surface and split surface?
What is close surface?
How do we give different draft angles from neutral element for a face?
What is the difference between square and cone in draft command?
Is threads visible in part design?
Is it possible to change the size of plane rep?
What is Replace?
What is Remove surface?
What is combine solid?
What is create datum?
What is mean dimension?
What is current operated solid?
What does keep edge option does in edge fillet?
What is user Pattern?
What is reframe on and define work in object?
What is save extension of sheet metal part?
What is selection sets?
How do you create pentagon or any other regular polygon?
What is Output feature? How it will be helpful?
What is publication?
How axis can be published?
What are the different types of parameters available in catia?
What is use of cut part by sketch plane in sketcher
What is Auto search?
Expand CAD/CAM/CAE/PLM/PDM/VPM/VPDM/CFD
Is it possible t create pocket or groove as a first feature?
How to give tolerance to particular dimension?
What is the meaning of menu dimension?
What is the use of create datum?
Can you pad open and intersecting profile?
Difference between PAD and MULTIPAD
Can you take portion of the one sketch for creating PAD?
What is DRAFT FILLETED POCKET?
Can we use ARC as axis for creating shaft feature?
What is difference between from top and from side option in stiffener?
What kind of profile should be there for creating stiffener?
Can I give two different angles for same face of solid by using draft option?
What does merge end's in rib option do?
What is user feature creation?
What is difference between create design table from current parameters and from existing file?
What is POWER COPY?
Is possible to add some parameters to existing design table?
Difference between POWER COPY & UFC(User Feature Creation)
Difference between PASTE & PASTE SPECIAL
Different option in PASTE SPECIAL
Is it possible to create negative body?
How do you differentiate positive and negative body?
Difference between assemble and add, remove.
How would U modify:
Front view using
Local axis system.
Selection sets
Copy & Paste?
Driving dimension?
Selection callout?
Types of:
Views
Selection view
Constrains
What is sewing?
What is Replace?
What is POWER COPY?
