Motion, gear wont stop rotating (video)
Johan Moberg
Hi!
I have a problem with a motion study. One of the gears wont stop rotating after it lost contact with the contact gear. When i use rotation with physical dynamics it works as it should but when I use motion simulation it just keeps rotating.
I've uploaded a short video where you can see the problem better. My only guess is that it's caused by SW simulating rotational inertia?
Any help is much appreciated!
Link:
Thanks!
What I understand is that when you use physical dynamics, it disregards your gear mate...hence, your small gear doesn't rotate when it's not in contact with the other teeth. When you use motion simulation, your gear mate is being used. When you rotate the larger gear, your gear mate is rotating the small gear because of the gear ratio.
